Old 08-17-2010, 10:26 AM   #1
SSGN
SSGN's Avatar
Liked 203 Times in 52 Posts
Question BBC oil pan?
Does anybody make a stock appearing pan with a screen or tray built in?I have seen them for SBC,from Milodon etc.If not what do you guys recommend as far as baffleing etc,this is not a stocker but a street car that see's the track a couple times a year.I want to keep it stock appearing.Thanks in advance
Kevin
Old 08-17-2010, 11:07 AM   #2
SSDiv6
Default Re: BBC oil pan?
Kevin
Canton Racing Products P/N 15-300. It has a slosh baffle built in.
You should also call Kevco Racing Oil Pans.
Old 08-17-2010, 11:17 AM   #3
danny waters sr
danny waters sr's Avatar
MILODON for sure.
Old 08-17-2010, 07:21 PM   #4
SSGN
SSGN's Avatar
Talking Re: BBC oil pan?
The canton and Milodon are stock pans with the same baffle as a GM production pan.With the stock GM pan you also use a bolt on windage tray with stand offs corrrect?The pans I am looking for have a windage screen or baffle mounted in the pan.What do most stock eliminator guys use for this application.Is the stock windage tray any good or even needed ?Thanks again
Kevin
Old 08-17-2010, 07:50 PM   #5
Liked 1,952 Times in 439 Posts
We use a stock GM LS-7 pan, and a baffle between the oil pan and the main cap. Some guys use the approved Moroso pan that has a welded sump extension.
Old 08-17-2010, 08:53 PM   #6
SSGN
SSGN's Avatar
Question Re: BBC oil pan?
I saw that pan also.I want to keep the stock appearing though.I guess the biggist concern we have is ,is it worth any HP to run a windage tray mounted to the caps or just a good stock pan?Thanks for all the input
Kevin
Old 08-18-2010, 07:55 AM   #7
SSDiv6
Kevin
Call Kevco racing pans. They may make the pan or even modify a stock pan for you. They build a great stock appearing small block pan with built-in windage and trap doors. They are good people and very helpful.
Old 08-18-2010, 11:27 AM   #8
sscrewcheif
sscrewcheif's Avatar
Send a message via Yahoo to sscrewcheif
stock appearing in aluminum?? Call Williams Performance Products. ask for Mickey. (951) 245-7144. best in the business
Big wheelies are for show!!
Go fast or go home!!!
sscrewcheif is offline   Reply With Quote
