Old 09-23-2010, 07:55 PM   #1
Rick Leininger Jr.
Default Stocker retainers & locks
I know some of the stocker valve springs get up to 550 lbs. open spring pressure. Are 7 degree retainers & locks working OK? or is 10 degree stuff necessary?
Thanks
Rick Leininger Jr. is offline   Reply With Quote
Old 09-23-2010, 07:56 PM   #2
Default Re: Stocker retainers & locks
We use 10 degree stuff from Comp. No failures.
Old 09-23-2010, 10:08 PM   #3
Jeff Lee
Jeff Lee's Avatar
I would think if I had 550#'s of spring pressure I would want the bead lock type.
That's insane by the way....
Jeff Lee 7494 D/S '70 AMX
Old 09-23-2010, 10:56 PM   #4
Define Stock Eliminator.
Old 09-24-2010, 06:33 AM   #5
Rick Leininger Jr.
It will be bead locks.
550 lbs. is what I am working on right now, why not go as far as the rocker will let you?
Old 09-24-2010, 10:05 AM   #6
Jeff Lee
Jeff Lee's Avatar
New coating for cam and lifters soon to be announced. They have been tested on Stocker cams. No wear to the parts while starting new engine with race springs like yours and engine run at idle only. PM me, you'll need it!
Old 09-24-2010, 10:35 AM   #7
Rick Leininger Jr.
I don't know how new it is?, the nascar engine shop I used to work for in 05 tried some coated stuff, worked on the flat lifters, not on the cam.
Old 09-24-2010, 04:31 PM   #8
Robert Swartz
Robert Swartz's Avatar
Jeff,
Do the cam and lifters both need to be new to use this process? Or can a previously run cam be subjected to this?
Robert Swartz
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
