Old 12-12-2010, 02:47 PM   #1
art leong
Default Best brake system to hold car on the line?
What's the best brake system to hold the car on the line against the converter
Art Leong 2095 SS
Old 12-12-2010, 03:15 PM   #2
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Best brake system to hold car on the line?
I have 4-wheel willwood disc brakes w/ master cylinder on my stocker and they work really well .Stop good at top end also ...
Old 12-14-2010, 12:34 AM   #3
art leong
Default Re: Best brake system to hold car on the line?
Willwood dosen't make anything that can fit on my car. My drive axles go through my front rotors.
Art Leong 2095 SS
Old 12-14-2010, 01:34 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
Hey Art,
What do the road course guy's use on there car's? Did the neon ACR or SRT come with anything better than stock? If nothing else they may have a better pad material available.
2009 V/SA Record Holder
Old 12-14-2010, 02:08 AM   #5
Jeff Lee
Jeff Lee's Avatar
a friend of mine makes specialty brakes for these kind of applications. Tell him I sent you!
Brian Hasty @ Fastbrakes
If you don't see what you want, just ask for it.
Jeff Lee 7494 D/S '70 AMX
Old 12-14-2010, 10:57 AM   #6
art leong
Brian Hasty @ fastbrakes
Thanks. I'll give them a call. One problem is the SRT 4 stuff is pretty good but you have to run at least a 15" wheel. Right now I run 14" wheels and due to them not making 14" tires anymore I'll need to use 13" wheels
Art Leong 2095 SS
Old 12-14-2010, 11:01 AM   #7
art leong
Originally Posted by Phillip marvetz View Post
Hey Art,
The SRT4 brakes are to big. I run the ACR stuff. But all Neons came with power brakes.
And I took off the power booster, but kept the stock mastercylinder. It stops fine at the end of the track but doesn't like to stop at slow speeds or hold the car against the converter.
I have new rotors and the organic pads.
Art Leong 2095 SS
Old 12-14-2010, 08:20 PM   #8
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
art if your still using the master from the power brake set-up , i'm guessing the pedal is rock hard. it has to large a bore for manual brakes. when running manual brakes you need to go to a smaller bore, and modify the pedal ratio.
i would get a brake pressure guage, and see how much you get at the calipers. usually 900 to a 1000 max should do. i'll bet now your in about the 400 range? if you want send me a pm with some info on the calipers ,master cyl.bore size ,and current pedal ratio, and i'll try to get you sorted out.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-14-2010, 10:41 AM   #9
danny waters sr
Cool Re: Best brake system to hold car on the line?
Sorry bout that Art. .....,
