Old 04-15-2011, 10:59 AM   #1
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
Default Trailer panels
I have a Forest River trailer with no ceiling panels and wondered if anyone DIYers have attempted to put some in? How about aluminum exterior replacements?
Gary Smith
"another broke racer spectating"
Gary Smith is offline   Reply With Quote
Old 04-15-2011, 01:08 PM   #2
FED 387
Liked 334 Times in 181 Posts
Default Re: Trailer panels
I did the ceiling on an enclosed trailer---Not a F River but another brand--Before I put up the paneling I ran all of my wiring for ceiling lites etc and then got foam bord insulation and glued it on with liquid nails, this will keep your ceiling much cooler. We then fastened the panels with SELF DRILLING screws to the roof cross studs/bars- much easier and quicker way of fastening them----for a nicer finished look we used the clear/white joining?? strips like they use on wall paneling between the 2 panels so you do not have any exposed gaps where two panels meet. Take your time and it will come out nice--measure 2-3 times BEFORE you do any cutting of holes etc so you don't waste any material and it cuts down on the number of mistakes/boo boos as you are installing the panels---good luck on your project---Comp
Old 05-02-2011, 03:09 PM   #3
gcasey
Liked 5 Times in 3 Posts
I'm interested in Gary's second question re exterior panels. I recently scraped the side of our Pace resulting in some small gashes about head high on the exterior. Are there any recommendations other than complete panel replacement? Don't know if trying to match new/old (white) panels will be an issue.
Appreciate any feedback
gcasey is offline   Reply With Quote
Old 05-02-2011, 06:45 PM   #4
FED 387
try a place that repairs semi trailers they can answer I'm sure all your questions---my opinion is yoy will need to replace the panel otherwise you will have a patch on the panel--do not know how that would look but call or drive over to a truck body/trailer place for all your ?????
Old 05-11-2011, 12:14 AM   #5
cad
cad's Avatar
Liked 93 Times in 52 Posts
If it's aluminum, the metal is now stretched and will never look right if repaired.
My neighbor's wife backed into my enclosed last fall with a bike carrier mounted on the rear. The cost to replace the 8'x4' panel and rear aluminum corner was about $750. Out local RV and trailer shop is who I used. Most RV repair shops can get you the panels.
Clark
