Old 04-27-2011, 10:20 PM   #1
Keith 944
Keith 944's Avatar
Default mopar starter question
i have a 73 340, have been told i can use a newer smaller starter from a truck, anyone know of the correct part, i need the year and model of vehicle, thanks, Keith
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-27-2011, 10:54 PM   #2
John Dinkel
Liked 263 Times in 68 Posts
Default Re: mopar starter question
New starter from Mancini Racing.
Item# MRE644
$129.95
You can buy a stock rebuilt starter for a 1998 Dodge pick up with a 318 or 360 from your local auto parts store.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 04-27-2011, 10:55 PM   #3
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
any 318 or 360 starter of truck from 92 to 2000
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 04-27-2011, 11:04 PM   #4
Keith 944
Keith 944's Avatar
thanks guys, thats what i was looking for, headed to parts store tommorow...
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-28-2011, 11:20 AM   #5
Hemiparts
Hemiparts's Avatar
If you need cross -reference # 56027702 ac is Chrysler part number
Chris
Hemiparts is offline   Reply With Quote
Old 04-28-2011, 11:35 AM   #6
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: mopar starter question
I've found that some OEM style mini-starters need a little clearancing. The area on the block has been around a hole that is in the bottom of the bellhousing area. I believe a spot there is usually machined at an angle, but for some reason, some starters still hit. Maybe it's something with slightly different starter bodies......just in case you run into that.
Old 04-28-2011, 04:56 PM   #7
Keith 944
Keith 944's Avatar
got one for a 94 pickup, was 64 dollars. the one for a 98 pickup was 98 dollars. looked like the same starter, still it fit and worked great, thanks for the replies
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
