Old 05-06-2011, 08:24 AM   #1
rt1092
Default Brake pressure gauge
Hi. Should a brake pressure gauge for staging a stocker be plumbed off the front or rear brakes?
rt1092 is offline   Reply With Quote
Old 05-06-2011, 08:40 AM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: Brake pressure gauge
Front. It will also show when you have your line loc on for the burnout.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 05-06-2011, 09:08 AM   #3
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Right. But, make sure you get one with a bleeder valve or you will have problems.
2894 STK
Old 05-08-2011, 08:10 AM   #4
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
I've installed mine on the front system, between the Lineloc and the front brakes. You can experiment with line pressure to see what works best for you, depending on your converter setup. It'll make it a little easier to leave more consistently.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
