Old 08-10-2011, 05:40 PM   #1
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Default Pre 1960 Chrysler Engine combos, how/can you use them?
I'm curious if and how would you go about using a Pre-1960 engine combo? Just curious if this can be done and what steps to take if I so choose to run an early combination.
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 08-10-2011, 11:01 PM   #2
Philip Saran
Liked 14 Times in 11 Posts
Default Re: Pre 1960 Chrysler Engine combos, how/can you use them?
I'm sure there are others who will chime in, but I think you would
need to see if those engine combos will fit into SSGT to be used?
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 08-11-2011, 01:31 AM   #3
cutta
cutta's Avatar
Thats what I'm interested in but the Chrys combos preceding 1960 aren't listed in the Engine Blueprint specifications.
Old 08-11-2011, 05:01 PM   #4
Philip Saran
If they are not listed in the blueprints sections, that would mean
that you would need to contact NHRA and request that a particular
engine combo be added.
Good luck in your search.
Phil Saran
Parker, Colorado
Old 08-11-2011, 07:55 PM   #5
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The only thing interesting in the fifties would be the dual carb 350s and 361s as well as the fuel injected 361 of which very few were made before they dropped it due to problems with it. I believe most of them are listed with a 1.95 intake which wouldn't be a big problem if they allowed the later heads in SS. There was a 361 dual four in 60 or 61 listed at 310 HP, these use the same carbs as the 383/343 which flow about 450 each on my bench, in GT this might be a great runner. An aftermarket fuel injection in GT would be great in if they accept the 361 FI.
Old 08-15-2011, 02:45 PM   #6
treessavoy
Liked 4 Times in 4 Posts
392 Hemi with dual quads or maybe some of the long ram engines?
JimR
Jim Rountree
