Old 08-28-2011, 10:28 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-69 396 & 427 Hi Performance Parts
3873858 square port heads rebuilt D-18-6 & E-2-6 $2500
3873858 square port heads bare F-13-6 & F-17-6 $1750
3904351 427 4 bolt standard bore block H-18-6 $5000
3919840 square port heads rebuilt F-17-8 & F-18-8 $1500
3935440 396 4 bolt standard bore block E-21-8 T0524MQ $1250
3955272 396 4 bolt L89 J-7-8 T1014JJ 1 of 311 $3000
3955272 396 4 bolt L89 J-14-8 T0527KG 1 of 400 $3000
3919840 square port heads both dated J-31-8 $1250
3919840 square port heads both dated C-25-9 $1250
3919840 square port heads J-31-8 & K-4-8 (slightly ported on exhaust side) $1100
6223 steel crank 10 on mains 20 on rods ready to go $300
8 inch timing cover with teeth design timing tab $100
#5271 primary metering block Holley carb $35
Secondary housing with screws Holley carb $15
3909879 F-24-7 & 3916178 F-28-7 smog exhaust manifolds repainted $500
330-770-2517 for any questions or pictures needed and can ship parts if you cannot pick up. All blocks and heads were cleaned and magged.
dlv4540 is offline   Reply With Quote
Search this Thread:
Advanced Search
