Liked 706 Times in 283 Posts
1985 MONTE CARLO SS
SUPER STOCK LEGAL GT/AA TO GT/MA SET UP FOR BBC/T-400 MILES 10K ON BODY WHEN PURCHASED FROM ALLSTATE INSURANCE FROM THEFT RECOVERY SENT TO ED QUAY AND SPENT OVER $12K IN BUILD OF CAGE AND SUSPENSION IN 1985 CHROME MOLY CAGE CERT T0 8.50 FUEL SYSTEM ALL MAGNA FUEL THROUGHOUT 2 PORT REGULATOR JETTED BYPASS RETURN 500 PUMP HI FLOW FILTER 5 GALLON CELL BRAKES LAMB/WILDWOOD CALIPERS AND ROTORS FRONT AND REAR MASTER CYLINDER AND BLOCK OFF PLATE 2LB INLINE PRESSURE VALVE SHOCKS AND SPRINGS FRONT DOUBLE ADJUSTABLE (30 PASSES) MOROSO TRICK SPRINGS (LIGHT BBC WITH NO COILS CUT) REAR DOUBLE ADJUSTABLE AND RE-VALVED BY LAMB FOR HEAVY CAR LAMB 130 LB SPRING WITH WEIGHT JACKS TO HELP SETUP 4 LINK AND RIDE HEIGHT SUSPENSION STOCK FRONT A-ARMS WITH REFITTED LOWERS TO HELP IN CAMBER ADJUSTMENT S-10 BOX VW STEERING DAMPNER 3 PASSES ON NEW HEIMS FOR FRONT END STEERING ($100) SEVERE DUTY 4 LINK MOUNTS AND RODS WHEN QUAY BUILT CAR 3 PASSES ON ALL REAR 4 LINK HEIM ENDS AND WISHBONE HEIM ENDS ($550) FORD 9 WITH REINFORCEMENT 5.67 PRO GEAR STEEL STRANGE SPOOL 35 SPLINE STRANGE STEEL THIRD MEMBER LONG AXLE IS MARK WILLIAMS RIFLE DRILLED SHORT AXLE IS STRANGE SOLID 3 1/2 DIAMETER DRIVE SHAFT ELECTRICAL STOCK HEAD AND TAILLIGHTS WITH SS DASH PAINLESS SWITCH PANEL ULTIMATE II PLAYBACK TACH 2 5/8 AUTOMETER OIL,WATER AND FUEL 1 5/8 VACUUM GAUGE SHIFTER CHEETAH REVERSE VALVE BODY AIR/ELECTRIC WITH BOTTLE AND REGULATOR ACD DUAL RPM SHIFT COMMAND CENTER MSD DIAL MODULE FOR RPM SELECTION ADJUSTABLE LONG TRAVEL TRANS BRAKE BUTTON EXHAUST MCCABE BUILT 2 1/8 STEP HEADERS IN 1996 BURNS STAINLESS STEEL MERGE COLLECTORS ($600 WITH 3 PASSES ON THEM) TIRES WELD 3.5 WITH 28 TALL MOROSO WELD 12 WITH 14X32 GOODYEAR (8PASSES) I HAVE OWNED THIS CAR SINCE 1989 AND ORIGINALLY IT WAS WHITE WITH RED INTERIOR AND REPAINTED FORD TEADOR RED IN 1995 NEW FRONT DRIVERS FENDER AND REAR SPOILER AND TAILLIGHT HOUSING ALL REPAINTED AND READY FOR INSTALL THINGS NEEDED TO BE RACE READY MOTOR,TRANS, BUILD CROSSMEMBER TO FIT OIL PAN, FRONT END ALIGNMENT, 4 ROTORS,INSTALL FENDER,SPOILER AND TAILLIGHT HOUSING, FUEL CELL LEAKS AT TOP WHEN FILLED COMPLETELY UP, MAYBE BRAIDED FUEL LINE AS IT MIGHT LEAK FROM SITTING DRY, 2 BATTERIES, UPDATE SEAT BELTS, NEW CHASSIS CERT. I do not have a title only a bill of sale. If a title is needed it will show as salvage due to theft recovery and stripped for more then rebuild in 1985. Asking $8500.00 OBO Phx AZ 602-768-3583 pics emailed if serious Last edited by Jeff Stout; 09-22-2011 at 05:44 PM. Reason: more |
Liked 69 Times in 30 Posts
you have a pm
Tried to answer. YOur email box is full. I can send pics on Sunday. If you have a email address then it will be easier to upload. Thanks Jeff
