1988 mustang 2900 lbs w/driver c4 tranny,5400 8 inch conveter 28x10.5
mt slick stock style suspension 4.56 gear aftermarket control arm and tubular k member. Car ran 10.29 @132.12 with 1.49 60 footbraking. 349ci smblk ford apox. 525 hp. Just wondering if the 60 ft can be improved and maybe a number I should be working toward. Thanks. |
Liked 333 Times in 180 Posts
you can set up a car to many different things---60 foot---- 1/8th ---1/4---ET--MPH what ever --- just cuz ya have a tremendous 60 foot time doesnt mean that the 1/4 is going to be fantastic too---now if the exact same or similiarly classed car car had a 1.39 vs. your 1.49 and the same 1/4 ET/MPH then you need to pick up your 60 a bit cuz a rule of thumb is for every .01 of 60 double it at the other end and take that time off your 1/4 mile ET and that's what your corrected ET should be--- for example 1.49 =60 and the 1/4 ET is 10.20 so if you could pick it up to say a 1.45=60 your 1/4 et should be .03x2+.06 new ET should be 10.14--- not carved in stone too many variables to consider but I hope this will give ya an idea
Liked 5 Times in 3 Posts
What low gear you have in the C4?
Liked 70 Times in 29 Posts
What RPM are you leaving at when foot braking?
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
Liked 227 Times in 74 Posts
Aa Greg says Low gear in the C4 2.92 or 2.75 is the common low gear sets for these. If you are at a stock ratio you can inprove a bunch. My Fox body mustang stoker is simular in wieght and rear gear mine is 4.88 and I run the 2.92 first gear in the c4 has had the best 60' of 1.52 et are 11.97. Do you use a 2 step also?
Any nitrous? Mine is a stock c4, 4.10 gear, 3120 lbs. with me, no nitrous. Usually 1.50 - 1.52 with 2 step at Bandimere runs 11.20's. San Antonio Nitro Jam last spring consistant 1.42's no 2 step. Footbraking at about 2000 rpm and stab the throttle. Ran high 10.50's -60's. Best 60' Saurday morning 1.405. Lots of fun.
![]() Jeff
Street legal 64 Falcon Sprint with 410W ![]() Stock - Super Stock fan |
