Liked 16 Times in 9 Posts
I've got a 67 RO/WO RC426 Steel Hemi bellhousing (1st pic) I'd like to install in a 68 street hemi. got the 172 tooth 11" flywheel, direct drive starter (3rd pic) but have run into a little snag. The top bolt of the starter attaches to the bellhousing via a 7/16 stud installed in the bell. Problem is the only way to secure the starter at the bottom is with a fine thread 7/16 bolt thru the bell into the starter from the back. Check out the 2nd pic. There isn't room for a bolt head, hex or allen, against the bellhousing and I don't want to take the grinder to this valuable, rare piece. Anyone know what was used for tightening the bottom of the starter to the bellhousing with? any insight greatly appreciated.
Liked 336 Times in 183 Posts
sounds like they used a double ended threaded stud with the appropriate thread size screwed into the block then position the starter to the bell housing and use a nut to finally secure the starter
problem is there is no mounting flange on the bottom of these starters accessable from the front...the bottom fastener must screw directly into the starter from the back not thru a flange like on the regular gear reduction starter.
Liked 427 Times in 97 Posts
marfen you have a pm
Liked 12 Times in 12 Posts
Have you fixed the problem yet...you could use an allen key round head bolt.
hemi moose ---those bolts are known as set screws===Comp
