Liked 101 Times in 27 Posts
If you read enough, there is one common descrepancy in all the different valve setting techniques from Comp Cams to Friendly Freddies Speed Depot.... everybody agrees that (SB Chev) when using the EO-IC method, set the INTAKE when the exhaust BEGINS to open......now the EXHAUST, the descrepancy---set the Exhaust when the intake just begins to close or when it is almost closed ??? Anyone ever noticed that or have a comment ???
Liked 1,908 Times in 427 Posts
You set the exhaust lash as the intake valve just closes, as in when the intake valve is almost on the seat.
Alan Roehrich 212A G/S |
Liked 54 Times in 27 Posts
With firing order 18436572, I checked the Mopar chart vs. base circle and it works very well:
TDC #1 firing, 2i, 8e rotate 90 deg. 1i, 4e 90 deg. more, 8i 3e 90 deg. 4i, 6e 90 deg (#6 firing), 3i, 5e 90 deg. 6i, 7e 90 deg. 5i, 2e 90 deg, 7i, 1e |
Liked 308 Times in 103 Posts
90 degree method does'nt work well with unsymetrical lobes or inv.radius lobes
ex opens set in/ in almost close set ex will work with anything as long as you rotate engine direction it runs. Mike Taylor 3601 |
Definitely x2 with some of today's race cams. You can always set one cylinder int & exh with this accurate method and check the lash the old Mopar sequence way to see if you really need to do it this way or your particular grind doesn't require it.
Liked 759 Times in 379 Posts
EO/IC is the method every professional engine builder and race team uses to set/check valve lash regardless of lobe or lifter type.
Go the the Pro Stock pits immmediately after a round of qualifying, walk over to your favorite Team's trailer/pit and watch them check their valve lash, one cylinder at a time, using the EO/IC method. |
My intakes are loosest when my exhausts are almost fully open. My exhausts are loosest when my intakes just start to close. Lobe separation angles have some influence there too.
Ed Wright 4156 SS/JA |
