Old 07-26-2012, 04:02 AM   #1
Phillip marvetz
Phillip marvetz's Avatar
Unhappy The saga of my Hemi has ended
Most of you know I bought a 426 Hemi engine from a fellow racer (Name withheld because I have been warned that if I mentioned it again I would be banned here) in Waldo Florida for my stocker awhile ago and had major issue's with what I received. It was completely illegal for stock and has been sitting in the crate for a few years. Since I'm not running stock this year I decided to get some use out of it and put it in the car last week and got it running. Today I took it over to my local chassis dyno to get it dialed in for this weekends B.C old time time drags, On pull number 5 it launched a valve thru #1 piston, and a bunch of coolant out of the left side header bank. It did however make 60 more hp than the bone stock street hemi short block it replaced on pull #4. Total junk.
I'm looking forward to building something that will be legal and run the way a Race Hemi should, It will be awhile before I can afford it though. Hopefully the block will be usable, If not I'm done for much longer.
2009 V/SA Record Holder
Old 07-26-2012, 09:47 AM   #2
Dion Hildebrandt
Dion Hildebrandt's Avatar
Default Re: The saga of my Hemi has ended
well that sucks...at least you are considering doing another engine.
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 07-26-2012, 10:06 AM   #3
tj310
Sounds like an expensive lesson. If you knew there were problems why didn't you have it checked beore you blew it up ? ---Trevor
Old 07-26-2012, 10:36 AM   #4
Harry 6674
I didn't read that he knew there was a problem just that it was illegal for stock. I'm sure if he felt there was a chance of the thing blowing up he wouldn't have ran it.
Harry 6674 is offline   Reply With Quote
Old 07-26-2012, 11:06 AM   #5
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
I hate when stuff blows up! Sorry to hear and hopefully some of the parts can be salvaged although as I recall from your original story, not much about that motor was good to begin with.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 07-28-2012, 06:56 PM   #6
gonzo1066
Bummer deal Phil I am sure that when the next engine is done it will FLY!!!!
gonzo1066 is offline   Reply With Quote
