Liked 83 Times in 24 Posts
Engine;
LQ9 Iron Block,line honed with ARP studs,Low milage LS2 rotating assembly,with Katech rod bolts. I'm guessing comp.ratio of about 10to1 ratio. LQ9(317) Heads fresh -.030" with new Comp.918 springs,New Yella Terra Rockers,ARP Head Studs,GM MLS head gaskets Comp.Cam new 54-000-1 .590/.578 230/236 114 LSA and new Comp. Hi-Tech 7.400 pushrods,LS7 lifters,new LS2 timing set Ported and shimmed LQ9 oil pump LS1 intake and TB,LS6 injectors,Professional Products Billet Fuel rails,Braided Teflon crossover with T and Gauge 6 Lt.truck coils,plug wires/Cool Sox,TR6 plugs New water pump and tensioner. Pinned Fluidampr #740102 New MSD Starter,Reman alternator K&N FIPK Exhaust; JBA Ceramic coated headers(Stage8 bolts/locks)JBA offroad pipes,with an extra bung/plug for wide band,stock 04 catback. Transmission; Freshly rebuilt Coan 2 spd Glide,manual valve body,trans.brake,NEW:JW Ultrabell for LS engine,ATI billet servo cover,ATI turbo shaft coversion,TCI deep trans pan. New 10" turbo converter with anti ballon plates front and back GMPP Flexplate/spacer. Custom made billet alum. trans.mount. Hurst Quarter Sick shifter with Long Pistol grip handle with button. Milidon flexable dipstick. Tube style cooler with teflon braided lines. Drive shaft; One piece-steel 3.5" HD,1350 yokes/u-joints,slip yoke,Drive Shaft Shop adapter Rear Diff; Stock Brakes; Rotors turned and plated Braided lines at rear calipers/machined banjo bolts for clearence/15" rims Fuel Tank; Stock with -10 fitting welded in/capped,-6 return in the top/capped Wheels; Weld RTS MT drag radials $13000 ![]() |
