Does the adjustable proportioning valve go before or after the line lock solenoid? And why? just trying to understand.... thanks!
Guest
Posts: n/a
I have a question to add to this? On a car with aftermarket racing discs on the front and drums on the back, what line do you install it on? Front or rear
Rear, which also answers the previous question.
Ed Wright 4156 SS/JA |
Now I am even more confused than before. Strange says that in drag cars it is usually in the front and street cars on the rear line.
Todd that is the same set up I have, discs in the front and drums on back. |
Guest
Posts: n/a
Same here Jamie. I bought new Strange front brakes and they told me to install it on the front. Willwood says to run it on the rear. My car had Willwoods on the front and it always seemed to have to much front brake bias. Strange also told me to run a 2 pound residual valve for the rear brake line.
Liked 165 Times in 59 Posts
something to try before you install the proportioning valve ,, if you have access to pressure gauges for brakes ,put one the front ,one on the back apply pedal pressure and read gauges ,,if its higher on the rear install on the rear ,,higher on the front maybe you don't need one or install on the front ,, my calipers are the same size on front and rear ,I put mine on the rear line gmonde
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 10-16-2013 at 05:12 PM. |
Liked 66 Times in 31 Posts
Put mine on the rear and have the valve all the way open. Should of left it on the shelf.
Liked 2 Times in 1 Post
Same here! Rear wide open.
RT - SS/X circa 1972. ![]() Talbot Racing Family |
Liked 6 Times in 4 Posts
