Liked 24 Times in 13 Posts
Anybody know what engine combo Danny is running at Indy in D/S?
Thanks
Mike Keener A/S B/S C/SM |
Liked 510 Times in 117 Posts
I'm pretty sure he's running the 350 horse 327.
68 Chevy11 327 F/S |
Yes... L79 - 350HP / 327".... factored down from the factory rating
Larry Fulton |
What a no brainer decision this is......327/275/274 vs 327/350/287!
Did I read the tech sheet correctly because the way I read it for 13 HP here is what you get: Heads, Valves, CAM, Compression ,an Aluminum High Rise Manifold, and a bit more carb. Naah..I must be dreaming or is this combination really a gift? Sure makes me wish I had a 66 deuce 4 speed !
Mike Keener A/S B/S C/SM Last edited by Mike Keener; 04-28-2013 at 03:55 PM. Reason: forgot a spec |
Liked 1,000 Times in 202 Posts
Hey Lynn..How are ya man?!
The way I read the 66 blueprint specs it looks like both combos us a small Holley but the carb notes appear to me that the 350 hp is a bit bigger than the 275 hp. In 67 the 275 used a QJet which is obviously superior, but the 350 disappeared at the end of 66 unless it hung around in a Corvette but I'm too lazy to look. I know one thing- there was never a 327/350 offered in a Camaro. Not even in a 69 car which which offered the most engine options I have ever seen.
Wouldnt it be a little less carb? The holley is rated at 585.the q jet around 700cfm.
| Thread Tools | |
| Display Modes | |
