Old 07-07-2013, 10:30 PM   #1
Maverick
Liked 36 Times in 26 Posts
Default removing scratches from lexan
I must have had something in my fiber cloth when I wiped my wind shield off and put some scratches in it. Does anyone have a method of polishing and removing the scratches, to make it better, or am I just going to have to replace the wind shield?
Steve Williams S/G 351N
Old 07-08-2013, 12:18 AM   #2
94 S/ST CHAMP
Default Re: removing scratches from lexan
http://www.novuspolish.com/
94 S/ST CHAMP is offline   Reply With Quote
Old 07-08-2013, 09:04 AM   #3
Keith 944
Keith 944's Avatar
unless it has mar-guard in it, you can treat it just like a thick coat of clear paint. it can be wet sanded and buffed. depending on how deep the scratch, 600-1000-1500-2000 grit, then buff with your choice of compound. (I use Maguire's diamond cut) you can also finish with Maguire's plastic polishes for optical clarity. I have done this many times, works like a charm.
p.s. the mar-guard is a scratch resistant coating, when you buff through it you would notice a slight difference.
To your original post, I am assuming these are very light scratches, so Novus/Maguire's etc. by hand will do just fine.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
