Old 08-16-2013, 03:23 PM   #1
FSA1673
Liked 12 Times in 6 Posts
Default GM A Body Drive Line Angles
What are optimum angles for this type of suspsension system. It seems I cannot get the angle of the pinion and the crank to be parallel. The engine/trans is pointing down by 5 degrees, when viewing car from the side it slopes toward the rear. The pinion is currently sloping down toward the ground as well. I have adjustable top trailing arms with heim joints each end and can adjust the angle of the pinion, which also affects driveshaft angle. I can also shim trans mount some as well until header clearance becomes an issue. Should I be more concerned with trying to minimize operating angles of the u joints at each end rather than relationship of the pinion angle to the crank angle.
Any input is much appreciated.
Thanks, Scott
FSA1673 is offline   Reply With Quote
Old 08-17-2013, 10:58 AM   #2
Run to Rund
Liked 56 Times in 29 Posts
Default Re: GM A Body Drive Line Angles
The nose of the diff will rotate upward on takeoff, so it should point down a little at rest.
Old 08-18-2013, 08:08 PM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
That statement may be confusing to some... And not exactly true....
This may explain the "pinion angle" concept better..... http://www.rosslertrans.com/pinion%20angle.htm
Old 08-19-2013, 08:17 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Scott, I thought I answered all your questions/explained how to check/set in our PM's last week.
Old 08-19-2013, 11:21 AM   #5
FSA1673
Ed You did.
I just like to get other's opinions on the subject. Never hurts to have agreement. I have everything all set up and will try it in a week or two to see if the changes help.
Any opinions on anti roll bar settings? No preload or pre load passenger side and if so do I make the links longer or shorter?
Thanks, Scott
Old 08-19-2013, 12:36 PM   #6
Stewart Way
Liked 70 Times in 22 Posts
One thing to remember as you look at the Rossler chart is that having zero zero is better than +two-two. Don't have the formula in front of me but I think a 3 degree ujoint misalignment eats 1% horsepower so if you are down 3 on the trans and up 3 on the rear to make them parallel then it is 1 or 2% loss. Don't remember if the formula is for 1 joint or a pair. Work to get 0-0 knowing sometimes you just cant.
Stewart Way 2424 SS
Old 08-19-2013, 04:57 PM   #7
1320racer
1320racer's Avatar
Originally Posted by FSA1673 View Post
Ed You did.
ok, just make sure that these others offering opinion have GM A body cars that leave on par with this one, launching off the footbrake and nearly 3900 lbs.
Old 08-20-2013, 08:11 AM   #8
Jim Kaekel
Liked 536 Times in 110 Posts
[QUOTE=1320racer;395446]ok, just make sure that these others offering opinion have GM A body cars that leave on par with this one, launching off the footbrake and nearly 3900 lbs.
The all knowing, 1320 Racer, speaks again. Get over yourself. That car is not a Stocker, not a Super Stocker. Anyone (with enough money) can stuff a high HP BB Chevy in a Chevelle, Firebird, etc., and go fast.
Jim Kaekel 3836 STK
Old 08-20-2013, 09:04 AM   #9
Rusty Davenport
Liked 101 Times in 27 Posts
[quote=Jim Kaekel;395533]
You took the words out of my mouth.....well said.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 08-20-2013, 10:36 AM   #10
1320racer
1320racer's Avatar
it ain't about "go fast", it's about getting these cars to work and neither would you know anything about!
Meanwhile, show us your car no mind another GM A body that has gone 1.28 60 foot with a bolt on suspenion, using all and nothing but the factory mounting points, nothing welded and no anti roll bar, launching off the footbrake and weighing 3900 lbs.
The Proof is in the Performance!
