Old 09-19-2013, 11:58 PM   #1
Ken Haase
Default adhesive residue removal
Is there an effective product out there that will remove the residue leftover from numbers without harming the Lexan? I appreciate any help. Thanks.
Ken Haase is offline   Reply With Quote
Old 09-20-2013, 09:22 AM   #2
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: adhesive residue removal
Ken,
Try WD-40 on a small spot, you will be surprised ? Rub lightly, till everything is removed .... Works great on decals ..... Good Luck,
Dave Ribeiro 1033 STK
Old 09-21-2013, 10:38 AM   #3
Ken Haase
Default Re: adhesive residue removal
Dave, I've used WD-40 successfully on painted surfaces before, and tried it on the Lexan. Didn't seem to work, but I'll give it another shot. Thanks.
Old 09-21-2013, 02:23 PM   #4
1855sc
Liked 3 Times in 2 Posts
did you try warming it with a heat gun at low setting or a blow dryer. then use wd-40 or stuff called goo gone. works on lexan & paint.
1855sc is offline   Reply With Quote
