Old 10-27-2013, 07:39 PM   #1
alejan1975
Red face 87 mustang Stocker - help me not get laughed off the track!
I have never raced in class racing but got my intro in the mid 90s working at a machine shop that built some stocker engines.
I have a cheap 87 mustang with th following
6 point chromoly cage
Stock motor down to the factory air cleaner
Spec stage 2+ clutch
SFI alum flywheel and blow proof bellhousing
Gutted Interior
Race seat/4 pt harness
33spline axles full spool 4.56 gears
Rear adjustable upper and fixed lower control arms
Weld 15x8 w new MT et streets
Weld 15x4 w mt front runners
My plan is to add:
Kooks long tube headers
Msd ignition
Front drag shocks
E fan
Manual steering Rack
Motor will be low dollar to start. I am taking a stock shortblock I have and will have the block cleaned, plate honed, and windage tray / studs, Line hone and decked, new cam bearings. Stock pistons cleaned, big end of Rods resized. If the crank will allow, offset grind .013 (will have to check how far the pistons will come out of the block- may pass if they would be out more than .005.
Was going to call comp and talk to their guys about getting a stocker grind Not looking to go custom - nit sure what they have but will prob shoot for a milder grind as i am cutting my teeth, and will have better luck with shifting, dialin it in etc if its not turnjng 8k rpm (also living w stock rod bolts And bo balance)
I have a set of stock heads laying around that we're rebuilt and run for 10k miles. I will have a fresh valve job addded and milled to minimum cc per the rules, and add appropriate springs and retainers.
Probably will stick with the stock computer and tune with a quarter horse tuner(allows me to flash computer w laptop).
Not expecting to set any records, hoping just to field a car that will get me started. Index is 12.85 if I looked this up right, I'm hoping to run 12.50s out of the gate with room to improve.
If I stick with it I imagine a real engine in the future along with faceplated trans, built rear etc.
So let me have it -where am I way off?
Thanks!
alejan1975 is offline   Reply With Quote
Old 10-28-2013, 12:51 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: 87 mustang Stocker - help me not get laughed off the tra
Ring seal - ring seal - ring seal
You need quality CP, JE or whatever quality piston is available for your engine along with quality rings such as offered by Total Seal or others.
And I seriously doubt the clutch you have will live much less perform well. There's a lot you can give up on the engine if you have a better than average suspension and clutch.
We've all been under budget restraints, just some things need to be done right or it will be nothing but frustrating.
Good luck.
Jeff Lee 7494 D/S '70 AMX
Old 10-28-2013, 01:28 AM   #3
Liked 5,150 Times in 1,966 Posts
I can't imagine that T 5 holding up very long with a V 8 .
You can slick shift 2, 3 ,4 and take the 5th gear out of it. Might last a little while..
Do yourself a spare one!
Going to have to do something with the shifter to keep from going from 2nd to 5th .
As Jeff said ..Good luck
Old 10-28-2013, 02:08 AM   #4
Rory McNeil
Gotta agree with Mark. When I started racing my 85 Mustang, I figured since I had been bracket racing my high 12 second daily driver 302 Fairmont for several years with a junkyard T5, that a T5 and street style clutch should be fine in my lighter and not that much quicker Mustang. I was wrong. By the end of that abbreviated 1rst season, I had 2 broken/damaged T5s. For the next year, I bucked up for a used Jerico DR4, and a used McLeod Soft Lok clutch assembly, which I had rebuilt by McLeod. 10 seasons later, the Jerico is still untouched, even with my mid 10 second bracket engine in the car the past 1 1/2 years.. Good used T5s are worth a few hundreds bucks each, busted ones, next to nothing.
NHRA 6390 STK
M/S 85 Mustang
Old 10-28-2013, 06:32 AM   #5
alejan1975
That's interesting - do you know why it didn't last once you started racing but was fine before?
I do have a spare that I was planning on rebuilding with G force internals. Supposedly they are good for 450 ftlbs but I've heard mixed things.
Thx for the input - ill look for ways to upgrade the trans/clutch
Old 10-28-2013, 08:42 AM   #6
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Would'nt skip balancing rotating assm,will live alot better balanced
Mike Taylor 3601
Old 10-28-2013, 01:10 PM   #7
Rory McNeil
Launching a street car at 3000 RPM is a lot different than leaving at 5500-6000RPM. Twisted the mainshaft on 1 trans, broke a main case on the other, also had a slider pile up on the hub. If you retain the stock mainshaft, that is a weak li9nk, regardless on how much HP the trans shop says the gears are good to.
NHRA 6390 STK
M/S 85 Mustang
Old 10-29-2013, 09:51 PM   #8
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Gutted Interior
My plan is to add:
Msd ignition
Front drag shocks
E fan
Thanks!
Alex feel free to call me at the shop during businesss hours for some help we can help you with advice and parts as we have built two of these from scratch into competitive record holding multi event winning championship caliber cars.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
