Old 10-28-2013, 10:09 PM   #1
ron b
Liked 4 Times in 4 Posts
Default 1968 mustang suspension question
i have a 1968 mustang,428cj, pro shifted toploader, soft lock, cal tracs. i got out for the first time this year sunday, union grove. made 2 passes both passes the car made a move to the left after the 2-3 shift. the only thing that i changed was put a 1/2 turn more preload on the passenger side cal trac. i have looked over the suspension and nothing looks broke. any advice. thanks ron b
ron b is offline   Reply With Quote
Old 10-28-2013, 11:55 PM   #2
D. Hake 4459
D. Hake 4459's Avatar
Liked 2 Times in 1 Post
Default Re: 1968 mustang suspension question
If the front end settles down about the same time it could be bump steer. Derek
Derek Hake 4459 H/SA 69' Roadrunner
D. Hake 4459 is offline   Reply With Quote
Old 10-29-2013, 06:03 PM   #3
ron b
i thought about that to. i have quite a few passes on the car and it usually goes pretty straight. weather permitting, i am going to set the cal tracs the same on both sides and go to the track sunday and see what happens. thanks ron b
Old 10-29-2013, 07:55 PM   #4
Todd Hoven
Guest
Posts: n/a
I had the same issue. Started with preload, and it always drove to the right. We ended up setting the bars by adjusting the passenger side first and then the driver side. Ran ran a flat of preload in each bar and the car went straight.
Old 10-29-2013, 10:06 PM   #5
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Ron feel free to call me at the shop to discuss your suspension in depth. M-F 10.30-6PM CST
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 10-29-2013, 10:30 PM   #6
ron b
thanks alex, i will give you a call around 11 tomorrow
