Big base circle cam in stock elem. just found out that it is not legal in stock.glad i did not ruin my block. was talking to kevin and Jeff the other day at lunch about getting my block opened up for the big cam and kevin told me that they had a call in to the tech dept to get a final ruleing. Jeff called me back and said that it was (NOT) legal.
Liked 99 Times in 49 Posts
How can they change their mind now I thought this was a done deal a year ago.. Not that they will ck for it any way.
Liked 127 Times in 49 Posts
Until it's in writing it's only hearsay not a rule.
Bobby Lundholm 3516 G/SA |
Liked 1,893 Times in 423 Posts
Well, isn't that just precious?
Anyone seen a ruling either way, in writing?
Alan Roehrich 212A G/S |
I wonder how many have machined blocks for 55mm and 60mm camshaft cores.
![]() Does it apply to Super Stock too? |
There would be a LOT of illegal SS engines if that were the case. Any cam, right?
Ed Wright 4156 SS/JA |
Guest
Posts: n/a
Now that is funny! There is a difference between repairing a block and machining the camshaft tunnel to use a bigger diameter cam.
Guest
Posts: n/a
I've never done it, but pontiac has problems with cam bearings. If you spin one and do excessive damage to the journal how would you repair it? They don't make an oversize cam bearing for my deal. I think the 50mm would be logical for a repair.
If it's not in the rule book it cannot be enforced. If that was the case they could make up any rule they wanted to and bounce someone just because they wanted to.
