Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 07-07-2014, 03:17 AM   #1
SSJ343
SSJ343's Avatar
Default Jerico 5spd with LONG V-Gate
We are having trouble with Jerico clutchtype 5-speed going from 3rd to 2nd gear, when upshifting to 4th. Shifter is LONG vertical gate and it stucks in the vertical slot and 2nd gear goes in.
Car is year 2000 B/Stock Firebird LS-1.
It is correctly adjusted with 1/4 pin.
Any ideas?
SSJ343 is offline   Reply With Quote
Old 07-19-2014, 09:39 PM   #2
BILL TAYLOR
Liked 200 Times in 62 Posts
Default Re: Jerico 5spd with LONG V-Gate
Any ideas?
I had similar issues with my Jerico/Long 4 speed. Call Long and ask for Mike (owners son). They put things on my shifter that made it impossible for it to not upshift. Been OK ever since.
BILL TAYLOR is offline   Reply With Quote
Old 08-10-2014, 12:56 PM   #3
SSJ343
SSJ343's Avatar
Default Re: Jerico 5spd with Jerico V-Gate
Sorry - I have double post on this issue. Whole story is here:
http://classracer.com/classforum/showthread.php?t=53835
It turned out to be Jerico Shifter. I made this post on Comp Forum in hope, that there is more Jerico 5-speed users online.
I have quoted a complete shifter from G-Force. At least they have common website with LONG.
Problem is still there and material has been added(weld) / removed / added. No results yet.
Old 08-12-2014, 11:20 AM   #4
SGE1340
Liked 4 Times in 3 Posts
I have found that i cant use the pin to adjust lingage, the slot in the 4/5th shifter plate must be rolled forward a bit, when the pin in the shifter trys to fall , it gets caught,
SGE1340 is offline   Reply With Quote
Old 12-30-2014, 12:17 PM   #5
hutt1
we had a similar situation with one of these type trans where the driver was sitting too far back and could not maintain pressure on the shifter and it would drop down in the notch when he relaxed and go to another gear when he pushed it forward. A 3/4 pad on the back of the shifter helped us determine that this was the problem. Scott
hutt1 is offline   Reply With Quote
