Old 10-30-2014, 11:31 AM   #1
Jim Bailey
Liked 584 Times in 94 Posts
Cool Alum Radiators for stockers ....2015
Does anyone know of a vendor(s) that makes custom Alum Radiators that are the same size and look just like stock ones ? - JB -
Jim Bailey is offline   Reply With Quote
Old 10-30-2014, 11:55 AM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Alum Radiators for stockers ....2015
I use to run an aluminum radiator from Griffin that had the upper & lower tanks stamped similar to the later "squarish" style OEM. They call them "Exact Fit". Not sure if that includes the older style "rounded" tanks.
After a little research, I guess they do!
http://www.griffinrad.com/load_detai...key_id=5-70024
LOCOMOTION Racing
Old 10-30-2014, 12:05 PM   #3
Jim Bailey
Thumbs up Re: Alum Radiators for stockers ....2015
Thanks Myron!
Old 10-30-2014, 12:08 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Alum Radiators for stockers ....2015
My bet is as long as the replacement has roughly the same dimensions it will fly. Good deal as the latest Mustang build will need a replacement anyway, but not sure of any great value as the factory piece is already plastic/aluminum....$79 at Autozone to boot.
Rich Taylor
I/SA - 321
Old 10-30-2014, 12:14 PM   #5
Myron Piatek
Glad to help, Jim. I don't know if there are any other manufacturers that have the OEM style tanks.
I am hoping that the more common and less expensive "box" style tanks will be legal for everyone. The overall style and configuration remains the same.
LOCOMOTION Racing
Old 10-30-2014, 12:19 PM   #6
HandOverFist
Like I'm going to run out and buy one of these for the Camaro lol... http://www.jegs.com/i/Be-Cool-Radiat...61#moreDetails
A little more sensible... http://www.jegs.com/i/Champion+Cooli...CC370/10002/-1
Rich Taylor
I/SA - 321
Old 12-10-2014, 09:00 PM   #7
brent flynn
brent flynn's Avatar
What is the actual rule? I was thinkin of something like this...would have to fab bottom brackets, and the top one, could be hid under the shroud bracket. It would be somewhat lighter than the champion 3 row, you mentioned above... what's your thoughts?
http://www.jegs.com/i/JEGS-Performan...oductId=752961
Old 10-30-2014, 12:37 PM   #8
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
I bought one of those $ 80.00 replacement radiators at AZ and they are super light.
They are super flimsy as well, ( soft aluminum) but the one core design does a good job of cooling the 302 with the A/C on.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 10-30-2014, 12:42 PM   #9
HandOverFist
Kind of what I figured. Ought to work well in the O/SA build.
Rich Taylor
I/SA - 321
Old 10-30-2014, 02:48 PM   #10
Dan Walcott
Liked 92 Times in 26 Posts
Jim, check manciniracing.com, they have alum. radiators that look OE. its about time,cost is the same,but easier to have the alum ones worked on.
Dan Walcott is offline   Reply With Quote
