Old 05-24-2015, 11:15 AM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default engine run on
Parked the car last fall everything is fine, Start it yesterday and now when you click it off it runs for several second before it shut off. I have checked the grounds, does not have a alternater, When I put a test light on the ing switch it stops like it should .Has a ARC switch panel. Anyone Jim Hanig
Old 05-24-2015, 11:35 AM   #2
Mike Jones
Liked 684 Times in 289 Posts
Default Re: engine run on
With the engine idling, you could unplug the ign. box to kill it.
Should stall immediately
That should point the way
Turn the key off before you plug it back in.
I don't believe you would damage your particular ign. system, but you will have to decide that.
Good luck
Mike A114 P/SA
Old 05-24-2015, 12:02 PM   #3
GTX5877
Liked 20 Times in 9 Posts
Electric fan backfeed? No relay?
GTX5877 is offline   Reply With Quote
Old 05-24-2015, 06:07 PM   #4
Bruce Fulper
Liked 54 Times in 33 Posts
Fresh fuel? Race gas dies quickly compared to street pump gas. Had this experience 25 years ago.
Bruce Fulper is offline   Reply With Quote
Old 05-24-2015, 06:37 PM   #5
Jim Hanig
Has a relay
Old 05-24-2015, 06:43 PM   #6
Jim Hanig
The fuel is a week old
Old 05-24-2015, 06:45 PM   #7
Jim Hanig
Does the panel need to be grounded? It is screwed to the plastic dash ?
Old 05-25-2015, 11:00 PM   #8
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Has a relay
Jim, did you check the relay? The contacts may have corroded over the winter and then it may have welded itself on during the first use.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 05-27-2015, 11:22 AM   #9
Jim Hanig
Well heres one for you I got al set to redo the wireing ,start the car and guess what it quit s like it suppose to.
