Old 09-21-2015, 11:11 AM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default 454 missing caps
I found two 454 2-bolt blocks over the weekend. Problem is, one is standard bore and missing all the main caps, the other is .030 over and missing the #4 main cap. Before or if I move on these I would like to know where to source the 2-bolt caps. I know they would have to be align bored or honed. Does converting to 4-bolt mains weaken the blocks? I thought about taking the caps off a 396 that's laying around. Was looking to use block in a 3/4 ton work truck.
brian schuetta is offline   Reply With Quote
Old 09-21-2015, 01:45 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: 454 missing caps
Mains were bored after caps were installed and caps don't all interchange well. The Register locates the cap so when replacing caps, it usually meant trying a number of them to find a close fit first. Once your close it can be align bored and or honed. You could find a cap that fit the register but the bore was off too far to align bore it. Aftermarket caps are small to allow for this issue. Most shops saved old caps just for this purpose.
Rich Biebel
S/C 1479
Stock 147R
Old 09-21-2015, 01:47 PM   #3
kansas stocker
Liked 250 Times in 49 Posts
For a work truck go find another block.
Way cheaper and faster.
Pete
kansas stocker is offline   Reply With Quote
Old 09-23-2015, 01:13 PM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
I have done a truck load of blocks like that, occasionally you will come across a block that is different than every cap you try, on those you can shift the cap by welding cap where it goes in block and cut the other side,to move it to where bore lines up,I use machinable nickel rod,
Mike Taylor 3601
Old 09-22-2015, 11:22 AM   #5
brian schuetta
Will pick through this guys storage, maybe I can find the one missing cap. If not will just forget these two and keep looking. I planned on using studs or new Arp bolts along with a 4.25 stroke crank. Thanks for your replies.
