Old 11-10-2015, 04:44 PM   #1
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
Default Accusump
Looking for some input on the benefits and best way to use the accusump in a stock eliminator 350 Chevy. I'm looking for the engine protection benefit but is it worth some horsepower as well and how many quarts of oil do you run with it in conjunction with a stock pan? 5 or 8 ? Is the filter adapter that Moroso makes the best way to plumb the lines? Does it increase bearing life much? Any other benefits?
Thanks for the input.
Rich
Old 11-10-2015, 05:06 PM   #2
danoone
danoone's Avatar
Default Re: Accusump
The are great for bearing life. We tore engines down and the bearings looked like new. We used the Moroso 3 qt unit and had the electric solenoid valve and used it to pressurize the oil system before starting.
danoone is offline   Reply With Quote
Old 11-10-2015, 05:17 PM   #3
rboyle
rboyle's Avatar
Do you use 5 or 8 qts of oil with it?
