Old 11-24-2015, 03:51 PM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Bypass fuel pressure regulator systems
Has anyone converted their carbureted combination to a bypass system? I'm talking about a system that uses small lines from the pressure regulator that go into a y-block and then back to the fuel cell. If so, it would be great to know what your results were (steadier pressure, additional MPH, ET improvement, or annoying side effects). Thanks.
Old 11-24-2015, 04:35 PM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
Default Re: Bypass fuel pressure regulator systems
My car is set up that way, mainly so I can go from EFI to carb. Would think best to confirm with your pump manufacturer to make sure it's up to the task. Can't imagine a down side....except of course the gentleman that had the "breaks up at 4500rpm" issue which was solved. BTW there is only 1 return line on my setup (Aeromotive) no Y blocks involved.
Joe Buchanan SS/BX 3117
Old 11-24-2015, 05:01 PM   #3
Jeff Stout
Liked 708 Times in 285 Posts
I have the Magna Fuel system on a super stock car. It is a jetted return from reg back to tank. I think a .035 jet into a -4 line to tank. What I noticed with my fuel pressure gauge is that the pressure stayed the same throughout the run with less needle bounce also. Cant say any ET gain.
Old 11-26-2015, 12:05 PM   #4
Alan Nyhus
Liked 800 Times in 237 Posts
When I put the bypass on, the fuel pressure was a bit more stable. Didn't see any performance improvement but the pump is noticeably cooler. Make sure to extend the bypass line in the tank so it's covered by fuel and isn't aerating the fuel in the tank when it dumps back in.
"That'll never work....."
Old 11-27-2015, 09:27 PM   #5
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Absolutely no change, no improvement whatsoever.
Old 11-27-2015, 09:35 PM   #6
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Mike, call John Rademacher @ Product Engineering, he can explain it better than me.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 11-27-2015, 09:51 PM   #7
1320racer
1320racer's Avatar
My fuel system is all John's aka Product Engineering. Again absolutely NO change, no improvement, no difference. Save your $.
Old 11-27-2015, 11:45 PM   #8
nhramnl
Thanks to everyone for their responses. Based on 1320racer's comments and photograph, I have to ask if you had a fuel pressure-based problem when you decided to put the bypass kit on? It looks from the picture that you're using -8 line into the regulator and either -6 or -8 out. Does the car use a QuadraJet, or a 4GC? I guess the key question is, were you hoping to cure a problem and the bypass didn't help (i.e. you still have the problem), were OK but put the bypass system on to guarantee you wouldn't ever have a problem, or put the bypass system on because you were assured that it would pick the car up? Thanks in advance for your answer.
Old 11-27-2015, 11:56 PM   #9
JHeath
JHeath's Avatar
1320 racer is an expert, even though he doesn't race a super stock car.
Jerry Heath
I/S '93 Cobra
Old 11-28-2015, 12:01 AM   #10
1320racer
1320racer's Avatar
Actually I do.
My car is a former super stocker built by the best, MPR, that now has a 900+HP BBC bracket engine under the hood that accelerates it well into the 8's and it's a safe bet I've made more passes down a 1/4 mile than most class racers over the past 25 years.
Back to the OP's question... -8 in and -8 out feeding a Holley 850. Just had the bypass kit laying around for years so I finally decided to put it on.
