Old 12-21-2015, 10:33 AM   #1
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
Default First Gen Camaro front suspension
I'm going to be replacing the front springs and shocks on my 1967 Camaro. Big block automatic mid ten second car. I currently use Moroso Trick springs and Comp Engineering three way adjustable shocks. I see that Afco sells a front shock with coil over springs. My question is this: Should I use this Afco style front suspension with the coil over springs, or stick with the Moroso springs and just use the Afco shocks up front? Or is there a better combination out there?
NHRA1926 is offline   Reply With Quote
Old 12-21-2015, 10:52 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Default Re: First Gen Camaro front suspension
Santhuff is the best for the gen 1 cars. They have springs, shocks and the coil over set up that you mentioned. I have their double adjustable shocks and ,moroso springs on my car. I don't know anyone that has run the coil over set up. I would like to hear if anyone has .
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
