Old 02-07-2016, 08:13 PM   #1
rod
Liked 20 Times in 15 Posts
Default section width ?
I started out with a 7" rim [because that is what I have] on a Phoenix F/X 9x28.5 slick. it has a section width of 11". what happens to the section width if I go to a 9" rim? does the diameter change?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 02-07-2016, 11:27 PM   #2
GTX JOHN
Default Re: section width ?
Hi Rod: Section width will get around 3/4 Inch Wider ( Possibly close to a inch ).
Height will not change very much at same Air Pressure
Tires are happiest when Rim is about the same width as tire
footprint on the ground ......give or take a inch or so.
See you at LVMS
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
