Old 04-04-2016, 07:45 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default valve to piston checking tool
This is without question a positive checking tool
ID:	33219   Click image for larger version
Larry Woodfin 471W
Old 04-05-2016, 11:35 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: valve to piston checking tool
Send it back, Larry. Got to be a cheap Chinese piece and won't last a week. Look at that machining! What did they cut it with, a rip saw?
Woodfin deserves Shiny!
Dale
Dale Shearon
68 Mustang 6394
Old 04-05-2016, 11:48 AM   #3
NORMAN BARNARD
Liked 2 Times in 2 Posts
well "duh"....did it come with a manual????
NORMAN BARNARD is offline   Reply With Quote
Old 04-05-2016, 12:00 PM   #4
Dragsinger
I had a lumber jack cut it with a chain saw
Larry Woodfin 471W
Old 04-05-2016, 12:06 PM   #5
Dragsinger
seriously,
because of angle milling and valve radius etc it is only specific to my engine. I initially cut the damaged head out of curiosity then realized it could be a cool visual aid.
I may touch up some of the chain saw marks with a rasp
Larry Woodfin 471W
Old 04-05-2016, 04:43 PM   #6
Ed Wright
Ed Wright's Avatar
I made a little fixture that hooks on my Jessel rockets at the push rod end, uses a 1/2" break over, using the actual heads & used head gaskets, "checking springs" installed, pull the valve down against the piston, measuring actual travel. Ex from 10 deg BTDC, until TDC. Intakes from TDC. to 10 deg ATDC. Two degree increments. I have checked mine with checking springs vs racing springs. On mine, subtract about .004" from the checking spring VTP clearance. I have learned how much I need with checking springs, so only check it that way now.
This works for me. If a pro has a different recommendation, I defer to them. This is just how I have done it for several years.
Ed Wright 4156 SS/JA
Old 04-07-2016, 08:05 PM   #7
Ed Wright
Ed Wright's Avatar
Larry, do you also have a tool (I think mine came from Moroso, about 20 years ago) that holds a dial indicator, sets on the gasket surface of the head, has an Allen bolt with the Allen head ground to fit in a head bolt hole to locate it. Put the ground bolt head in the short head bolt hole in the head, indicator stem touches the face of the valve head. Measures the distance from the head gasket surface to the face of the valve. I use it to verify my valve hight are all equal. Intake all the same, exhausts all the same. If you used one (you may have) to get that piece of a head there to verify they measure the same as your race heads. Then, that would be an accurate clearance checker.
After that, I measure valve drop to the piston @ TDC on all valves. I have caught piston valve pockets off over .010". I'm kinda anal about all my clearances. I can't afford to be knocking heads off valves. Hell, I can't really afford to be doing this anyway. I need to quit. Getting too old.
Old 04-08-2016, 06:46 AM   #8
Dragsinger
Ed, knocking heads of valves is VERY expensive Doing so has set me back a full season.
And yes, I will verify the checking head dimensions are the same as race head. Gary Hettler is doing a replacement head for me and also has the "good" head for double checking.
The cut up head is mostly for fun, I will verify the clearances with new race head.
I expect everything to be OK and "maybe" make the D 4 September race at Thunder Road.
One thing about the cut up head, it is a good conversation piece. At the shop a number of folks have noticed it and looked it over. The same comment from everyone, "I did not realize how the water passages look"
Larry Woodfin 471W
Old 04-08-2016, 08:00 AM   #9
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
X2 I have one of those, too.
Old 04-08-2016, 11:38 AM   #10
west coast
Liked 230 Times in 75 Posts
Yes it is all about how much deflection your combo has. From what type of rockers you have is a huge in deflection shaft, pedestals or studs. also the length, diameter and wall thickness of the push rods it all adds up. so pushing your cam lift to your max spec and not going over is hard to do when ordering cams. My tear down last year when we measured it was really legal enough to think we were doing something wrong when we measures it.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
