Old 07-18-2007, 11:20 AM   #1
Stick Racing
Default Battery powered air compressor
Noticed in a picture in the Dragster, Ralph Porpora was using what looked to be a small battery powered air compressor. Something handy to make a last minute change in tire pressure while in the staging lanes.
Anyone know where to find one of those?
Andy Stone B/S 1102
Stick Racing is offline   Reply With Quote
Old 07-18-2007, 11:51 AM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Battery powered air compressor
I don't know what he had, but I've used such compressors from Home Depot and Walmart. I remember them being around $40. But you have the issue of securing it in the car while racing. That's why I use a small bicycle foot pump I keep in the car for in the lanes, which can also be locked in a rather small metal tool box bolted behing my seat. The compressor I use after each race to make sure the tires have enough air the next day after overnight cooling. Then I recharge at the motel.
LOCOMOTION Racing
Old 07-18-2007, 01:43 PM   #3
JCQuinn
Liked 2 Times in 1 Post
Default Re: Battery powered air compressor
I bought mine at Sears it is part of their 19.2 volt line of tools. I love it it even has a built in pressure gauge.
JCQuinn is offline   Reply With Quote
Old 07-18-2007, 10:30 PM   #4
Stick Racing
Appreciate the info. Stick cars tend to beat up bias tires in a short period of time. On a cool night, you have to be careful not to let too much air out before you run. If the race is stopped for 10-15 minutes, you are in trouble. I have found the air leaks out of the tire screws much faster than than the sidewalls. Still not brave enough to run without screws.
If I go with the battery powered compressor, I most likely forget to charge the battery. If I go with the bicycle pump, I have arms like Hulk Hogan.
Decisions, decisions....
Thanks, Andy
Old 07-18-2007, 11:31 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Battery powered air compressor
Not to worry, the battery lasts quite a while and will fill several tires per charge, then you plug it in to a 110 for a while and away you go again. I bought several and got them at WalMart ($ 35-40). Every racer should have one or two! Jim
Old 07-19-2007, 05:58 AM   #6
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
http://quartermax.users21.edigita.co...=1009&catID=48
A bracket racing buddy of mine uses this pump. It is slick to have with you in the lanes, and the battery lasts pretty well. He says with a second battery this thing would be priceless.
I want one for christmas.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
