Liked 165 Times in 51 Posts
I have a new 12 bolt housing from STRANGE.
I was going to change the gears and I have a set of RICHMOND gears. The pinion gear on the new RICHMOND is 3/16 shorter than the gear we took out of the car. The new gear will not fit. Any idea what gives here. I thought all series 4, 12 bolt, gears were the same? Thanks!
Glen DeMenge 1969 Camaro Stock Eliminator |
Liked 1,929 Times in 434 Posts
The pinion gear is 3/16" shorter where?
Which ratio? Are both gear sets Richmond? The same series?
Alan Roehrich 212A G/S |
Liked 800 Times in 237 Posts
I've never seen any 12 bolt gears where the pinion was shorter in depth, which is what I take it you're referring to?
Post a pic of the new and old pinion side by side.
"That'll never work....." |
Liked 250 Times in 49 Posts
does the ring gear work?
i'm betting you have got a set for something other than a 12 bolt. pete |
Liked 336 Times in 183 Posts
could it be a BOP gear set???
Liked 319 Times in 68 Posts
Have a strange 12 bolt in our stocker,never any problems with any brand gears, you probably have wrong gears.12 bolt truck or BOP stuff.
Lee Valentine 1661 STK |
After looking at it I see the pinion will not pass through the bearing in the case.
new one has the bearing on it.
Glen DeMenge 1969 Camaro Stock Eliminator Last edited by MEXJOE; 10-28-2024 at 02:18 PM. |
Liked 288 Times in 109 Posts
it appears that you simply have the wrong gear set. Maybe boxed wrong or looked up wrong number.
Liked 33 Times in 16 Posts
If we had the number it could easily be solved...we can see the packaging in your image.
![]() Is this it? https://www.summitracing.com/parts/r...27-1/overview/
Rich Taylor I/SA - 321 Last edited by HandOverFist; 08-07-2016 at 01:10 PM. |
Liked 320 Times in 102 Posts
If you think you have a problem just measure from the area that the front pinion bearing mounts to the end of the spline.....
Measure the bearing mount diameters of the front and rear pinion bearing.. Does the companion flange fit the new gear set??????????? Just looking at the pix it just appears that difference is the length of the gear teeth on the pinion caused by a ratio change..... Just my 2 cents.... Bob
