Old 11-18-2016, 05:30 PM   #1
65hardtop
Default Carb number question
In stock, If I have a carb that does not have a number that is on the list of acceptable
carbs but has all the correct dimensions is that ok or not?
Thanks
65hardtop is offline   Reply With Quote
Old 11-18-2016, 06:14 PM   #2
bob3240
Liked 16 Times in 5 Posts
Default Re: Carb number question
Yes, NHRA stopped making us have the matching numbers years ago
bob3240 is offline   Reply With Quote
Old 11-18-2016, 07:21 PM   #3
Jim Caughlin
Liked 806 Times in 246 Posts
What? Your saying that if the bores and venturis are the correct size, it's legal??? Not in the part of the country that I race in.
Jim Caughlin is offline   Reply With Quote
Old 11-18-2016, 09:45 PM   #4
Coleydog
Liked 53 Times in 38 Posts
Every AVS carb from 68-70 on the 340 and 383 have identical bores and Ventura size, I doubt those little numbers on the corner mean much now after 50 years.
Old 11-18-2016, 10:59 PM   #5
jmantle
Liked 172 Times in 81 Posts
Jim, NHRA relaxed the rule several years ago. Still has to be the correct carb with the correct throttle bore and venture dimensions, numbers don't matter.
Jim Mantle
jmantle is offline   Reply With Quote
Old 11-19-2016, 08:48 PM   #6
Jim Caughlin
I understand the part number part of this question but you better make sure that things are configured as original. I have seen these items get someone bounced (at least on Holley carbs):
Center pivot bowels that weren't OEM
Dual inlets that weren't OEM
Changing metering plates to metering blocks
Secondary idle circuits
Throwing away the vacuum secondary parts
Polishing bores (even though they measured legal)
Milling down the throttle rods
Secondary accelerator pumps that weren't OEM
There is a lot more to what constitutes a legal carb than just bore and venture.
If any carb that meets the measurements are legal, why does NHRA have a list of legal replacements, wouldn't any carb that measures correctly be legal?
I know my case is a little different (SS modified), there are specific carb numbers and minimal modifications that are allowed. Every time I have been torn down, the carb gets a very careful visual inspection beyond the obvious measurement check.
Jim Caughlin
SS6019
