Liked 203 Times in 80 Posts
I can not find anybody who makes these spools. I have one in my possession now and am considering making them if I can draw enough interest. Chime in if you have input about this topic.
Mike Fuller 396 STK 3961 SS |
Liked 9 Times in 3 Posts
I don't think it would sell that well, in order to use the 40 spline spool, you need at least 3.250 bore housing. those are only available in a new aftermarket housings. the stock housings are 3.062 bore, . secondly the 40 spline I.d. on a 3.250 o.d. on the bearing is marginal for strength , thirdly if a 35 spline axle isn't enough for your application, you should be looking at a dana 60 or 9'' in my opinion.
Mark Markow 171 ss/tb |
Liked 99 Times in 60 Posts
Agree with Mark about a limited application. At the performance level of needing a 40 spline axle, the 12 bolt gear set is beyond the design limits.
Larry Woodfin 471W |
Liked 53 Times in 13 Posts
Mike, Strange makes one, It's for the 12 bolt drop out center section that fit a 9" housing.it's used by the comp guys. I have one in my Race car. I run a DTS 12 bolt housing with MPR chromoly tubes...Luke
Strange no longer makes it. Like I said I have one now and the application that you talked about is what I plan to use it for.
Liked 63 Times in 7 Posts
There are bearings, that will fit a stock, 12 bolt housing bore. These bearings fit this 40 spline spool, plus the Strange & Mark Williams aluminum 35 spline spools. These are very expensive, aircraft landing gear bearings, but you do not have bore the housing, to use these spools. Google my name to find my contact information.
Eddie Rezac |
#7 | |
Liked 591 Times in 163 Posts
Call me or PM if interested. (631)461-6761 |
I would like to buy one of these 40 spline spools for the Strange drop out 12 bolt carriers. New or used.
712 363 3801 |
Also check with Frank Parks(Neal & Parks). They make and have many of the needed components.
