Old 02-20-2017, 11:51 AM   #1
ZenzenRacing
Liked 53 Times in 17 Posts
Cool Pac vs Manley
SBC SS engine, PAC vs Manley Nex-Tek spring? Whats good and whats bad?
ZenzenRacing is offline   Reply With Quote
Old 02-20-2017, 12:51 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Pac vs Manley
Both make "good" springs--- too many variables to ask that question--- need info on Cam lift- suggested spring pressures- RPM range engine will be operated in/spring diameter/installed height etc./spring treatments polishing etc. etc.-----might want to look at PSI also compare the 3--- PAC & PSI generally are a step above Manley due to their steel/manufacturing treatments etc. etc. but I'm not saying to use one over the other it all depends on your set up---FED 387
Old 02-20-2017, 01:29 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
I have to say the last set of Manley 448 springs I got were the best ever from Manley.
Over 200 runs with no broken springs and only 10-15# loss of pressure across the board.
And that is on a 8300rpm Big Block with a .900 lift cam .
I've used PAC , PSI and Manley , It seems Manley may have caught up with the reliability. AND they always pay the contingency , had issues with the others.
Old 02-20-2017, 02:48 PM   #4
richie 2
Liked 205 Times in 93 Posts
yes time for a new set on my 327ci...same recommendations? matching retainers & locks or r they a different brand...tks.
Old 03-09-2017, 03:57 AM   #5
trmnatr
Crane Cam's springs are also good. They have some made by PAC and some not. Their 1.55" and 1.625" is made for them and are excellent (96886 and 99880), and their Posi-Stop or standard retainers fit correctly including ID locators.
I like both Crane and Manley
trmnatr is offline   Reply With Quote
Old 03-09-2017, 08:38 AM   #6
Ed Wright
Ed Wright's Avatar
I have been using PAC 1356 springs (1.5" dia) for a few years now. I put new springs on every year, just to be safe. Just an LT1, mine never sees over 8500. Usually 8300 at the stripe. Have never broken one, and have never seen much pressure loss. I have three sets sitting here I would have no problem using again. I can torque the center head bolts with these 1.5" diameter springs installed, and don't have to clearance the rocker arms for them. Best springs I have had.
Ed Wright 4156 SS/JA
Old 03-19-2017, 09:05 AM   #7
drgrcr1156
Liked 2 Times in 1 Post
Tom,
What rear gear are you using with that combination?
Bob
drgrcr1156 is offline   Reply With Quote
Old 03-09-2017, 12:37 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Re-read post #2.
Start with your cam card recommended spring pressure. PAC and Manley make hundreds if not thousands of different pressure, height and configurations from several different spring steel alloys and processes (PAC alloy, "Super Clean" ect.). Find out about those and work from there. Don't forget valves, push rods and rockers. Make sure everything's going to be happy in there.
I spent months on this before deciding on AFR 8001 {PAC 1225) springs for my SBF.
Dale Shearon
68 Mustang 6394
Old 03-09-2017, 01:01 PM   #9
Jim Kaekel
Liked 535 Times in 110 Posts
My experience is that PAC's quality control leaves a lot to be desired. In each set I purchased from them, I had to exchange at least one spring because the rate was way off compared to the others in the set. I just purchased a set of PSI's and they were spot on.
Jim Kaekel 3836 STK
Old 03-09-2017, 01:34 PM   #10
Ed Wright
Ed Wright's Avatar
Guess I've been lucky. I'm on my 4th set now, and I check every spring in the box. Have ever seen that.
