Old 04-10-2017, 06:08 PM   #1
Todd Gross
Liked 54 Times in 24 Posts
Default Energy Recovery Oil Pump traits?
I have a customers LS engine that I installed an energy recovery oil pump in. Last season with a standard volume Mellings pump and 5/20 or 0/20 oil @ 120f max coolant temperature, the car would leave the line at 90PSI and go through at 78 to 82.
With the new pump, first warm hit on the dyno, it shot up to 150 psi and stayed all the way through ( may have been higher as the transducer on the dyno is rated at 150# max). It had the smallest spring and the the poppet ball moved freely.
I talked to Vern S. about the pressure and he was very helpful and talked through things to great extent. In the end he theorized that the oiling system in the engine was very efficient and recommended shortening the spring and teeing the bypass hose to route some of the bypass oil to the screen / box area of the pick up and the other back to the tube as originally designed. He also stated if pressure is still to high to shorten the spring at .030' increments until I get what I want.
Now with that done with warm engine , 0/20 oil, it idled at 40 to 50# and shot up to and leveled at 100 / 105# as soon as the throttle was snapped. Still to high.
I have made adjustment to shorten the spring another .030". Customer will have it running this week and hopes to test.
Has anybody run into a similar experience? This is the first time I have utilized this type of pump and although I understand the theory of the energy recovery pressurizing the inlet side of the pump, I am still really surprised that a thinner pump develops higher pressure ( w/ short spring ) and ramps up so quickly compared to the Mellings on the same engine.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 04-10-2017, 06:31 PM   #2
SSDiv6
Default Re: Energy Recovery Oil Pump traits?
Vern Schummann knows his stuff and makes various versions of his oil pumps for each engine application.
If your application is for a Stock or Super Stock engine, this pump is an overkill.
This Energy Recovery version of his pump is more effective when used with a Petersen external oil pressure regulator and to adjust its operation, in lieu of an oil pressure gauge, you use an inline flowmeter and adjust the oil pump for a specific oil volume flow.
I know of a racers that have been using the Energy Recovery oil pump with the external regulator successfully on high RPM engines making 1000+ HP.
If your application is a Stock Eliminator, his Pro Standard version of the pump would suffice; if a Super Stock, you can use either the Pro Standard or the Pro Maxx version of the pump.
Old 04-10-2017, 07:32 PM   #3
Todd Gross
You are absolutely correct about Vern knowing his stuff. I'm not disputing that or knocking his product. I'm just trying to get as much understanding as I can to feel confident about my customers oiling system.
This pump was special ordered and speced out for a Factory Stock application when ordered. With that said, using an external regulator is not accepted as I'm sure you know.
There are others in F/S using the energy recovery pumps that is why the owner requested to switch over.
Todd Gross
3323 FS/E,F
Old 04-10-2017, 09:40 PM   #4
SSDiv6
The regular LS OEM oil pump puts out 4~6 GPM's of flow and will cavitate past 6000 RPM. The Schumman pump has an output of 8.5+ GPM's past 6000 RPM's.
Ask Vern how low you can go on oil pressure and still keep at minimum 8.0+ GPM at high RPM's without cavitating.
Also ask Vern if he has a weaker relief spring that would do the job in lieu of cutting more of the spring.
Eventually with use and heat cycles, the spring will change its tension.
Old 04-11-2017, 10:12 AM   #5
Signman
Liked 269 Times in 99 Posts
Are you running a paper oil filter or screen?
Old 04-11-2017, 03:23 PM   #6
Todd Gross
Screen filter. I do not know how many micron off the top of my head.
Todd Gross
3323 FS/E,F
