Old 08-03-2017, 12:52 PM   #1
Jeff Stout
Liked 708 Times in 285 Posts
Default Adding weight to a 4 link G body?
I built this car like my old Super Stock Monte aftermarket 4 link with the exception of mini tube and using 12x30 tire. My question is I need to add weight and I know on top of the rear end is a great place, but wanting to know adding weight on frame where 4 link would intersect would be a great place. I'm looking to add 150lb at floor behind drivers seating and my thought was 4 link would work rear tires harder and plant them better knowing it had the weight at the intersection of 4 link. Any thoughts? Thanks in advance. Jeff
Old 08-03-2017, 04:12 PM   #2
Jim Kaekel
Liked 536 Times in 110 Posts
Default Re: Adding weight to a 4 link G body?
Rear seat belt hold downs.
Jim Kaekel 3836 STK
Old 08-03-2017, 04:53 PM   #3
Jeff Stout
Thanks Jim. I had someone private message me the same location but try to go higher such as rear roll cage down bars. Now to come up with 150lb and secure as I only have 60lb of lead.
Old 08-03-2017, 05:53 PM   #4
Rsmith38
Liked 28 Times in 15 Posts
If you mount a weight box (Moroso - Competition eng) to the hold downs (or a flat steel plate) you can add pieces of steel, wrenches, etc to the box - in addition to the lead.
Rsmith38 is offline   Reply With Quote
Old 08-03-2017, 06:21 PM   #5
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Keep weight below the top of the wheelwells (per the rules) Weight ahead of the rear axle will add some static weight to the front end , but could add some dynamic weight during the launch .
Old 08-03-2017, 07:02 PM   #6
Jeff Stout
Thanks for reminding me about height at wheel wells per rules.
Old 08-04-2017, 11:12 AM   #7
Rusty Davenport
Liked 101 Times in 27 Posts
Can the weight box be secured by a thick "sandwich" plate under the car or does it have to be welded to a structural member of the car ????
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 08-04-2017, 01:27 PM   #8
Rsmith38
Mine is bolted thru the pickup bed - Been thru tech at Nationals and Divisionals for years - don't know if it is in the rule book - 6 bolts on the Moroso box.
