Liked 53 Times in 13 Posts
GM/Callies COPO 396 Crank 3.825 stroke # 19301270 std-std. Gun drilled mains and rod journal 58X wheel $795.00 or best
GM stage 3 hyd. roller cam # 88958773 $225.00 PSI max life beehive valve springs for GM stage 3 cam with retainers,cups and locks $150.00******SOLD******* GM LS-9 rocker arms 1.7 ratio with stands and bolts $150.00 Trend double taper push rods 7.375 x .080 $110.00 8 COPO 396 Injectors same as ( LS-7 ) 43lb/hr @ 58PSI $200.00 GM 6 qt. cast oil pan with tray/pick up tube and bolts from COPO camaro $120.00 ARP Main studs for LS new in box. $ 225.00 **** SOLD***** Hamburger #1061 brushed alum. valve covers with hardware for LS. will clear Jesel Rockers. New $200.00 MAHLE LS-3 Main Bearings MS2294H/ MS2294 HX/ MS2199HXK. new in box ***** SOLD***** MAHLE LS-3 Rod Bearings CB 663HNK-1/ CB 663HXNK New in box ******SOLD***** SB Chevy Parts Used set of JE 350-255 super stock pistons .060, Lightened and new coated top and skirts .927 pin hole, Radial ports $300.00 Victor E super stock intake by heads up with Wilson Holley to Q-jet adapter. New $400.00 *******SOLD******* Quick fuel Holley 750 DP. carb. $ 300.00 B/G 400 fuel pump works great comes with rebuilt kit and 4 port BG fuel regulator $275.00 MSD HVC 2 Coil # 8261 $125.00 Crane ultra lite Roller lifters $125.00 Hooker 3 step SBC headers for 93-02 Camaro-Firebird Super stock coated nice no dents $400.00 all COPO parts have 12 runs on them SBC parts are used not used up unless noted...make offer...Luke 248-342-3117 Last edited by rx dealer; 09-25-2017 at 02:16 PM. |
Liked 21 Times in 7 Posts
Have you sold the main bolts yet?
Still have them.
Do you still have the lifters?
Hi Rob. I do have them
