Old 11-06-2017, 01:03 PM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default 83' Camaro Top Strut Mount.
I noticed the rubber bushing in my top strut mount( camber plate? ) is cracked and falling apart. My search at the junkyard turned up 8 that were in worse shape than mine. Found some in the shed that are in good shape but brings up the question, is an aftermarket piece available or is there a way to eliminate the rubber altogether? Junkyard parts are getting harder to find for these cars. I use an old set of Koni struts up front. Thanks in advance guys.
brian schuetta is offline   Reply With Quote
Old 11-06-2017, 02:02 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 83' Camaro Top Strut Mount.
One option, the factory replacement upper mounts are still available. Check your local parts store for Moog or other brands.
Larry Woodfin 471W
Old 11-06-2017, 02:05 PM   #3
Dragsinger
another option, Racecraft
http://www.racecraft.com/index.php?m...roducts_id=351
Larry Woodfin 471W
Old 11-06-2017, 02:30 PM   #4
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
If you go with OEM, I believe the Z-28's and IROC's had a bearing, where the cheaper models had a bushing ...
Jeff Niceswanger 3740 SS
Old 11-06-2017, 03:19 PM   #5
brian schuetta
Jeff, will check that out. I don't remember seeing that before but will check, have access to many examples. The ones I dug out of the shed have bushings. Will price new pieces also. Nice Kit shown there, maybe in the spring time.
Old 11-06-2017, 04:35 PM   #6
FED 387
Liked 334 Times in 181 Posts
look on eBay top strut mount plates lots of the with the bearing no bushing about $55-75 per pair---Fed 387
Old 11-11-2017, 08:05 PM   #7
brian schuetta
The quick fix now has been a set of junkyard pieces with bearings I found. The issue was glass beading them and having trouble getting that stuff out. But it it did work. Will look at aftermarket parts this spring.
