Liked 28 Times in 15 Posts
Where is the port to test line pressure on a TH-350? With my car in low gear it will move forward 15 ft., then when I stop it won't move again. The engine just revs but the car doesn't move. Went through the shifter adjustment and the fluid doesn't smell or look burnt. Thanks.
Liked 15 Times in 11 Posts
Right side of case (passenger side), near tail housing; there is a hex head 1/4 npt plug.
Liked 5,145 Times in 1,964 Posts
Yes..rear most port, except it is 1/8 npt
Between the modulator and the servo?
Right side of TH350 case.
Rear port is main line pressure. You will see pressure here in all gears for most valve body configurations. Some race-only valve bodies may not have pressure at this port or the others Middle port is 2nd gear pressure Front port is third gear pressure
Liked 133 Times in 76 Posts
http://www.crankshaftcoalition.com/w...0_rebuild_tech
Scroll down for pic of the ports. |
