Old 05-16-2018, 05:29 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Front tire pressure adjustments
Will lowering my front tire air pressure slow my reaction time down. I run 40 lbs. is that normal or high or low.?
Kdw1403 is offline   Reply With Quote
Old 05-16-2018, 05:31 PM   #2
FED 387
Liked 335 Times in 182 Posts
Default Re: Front tire pressure adjustments
should!- pressure compared to what?
Old 05-16-2018, 05:41 PM   #3
Kdw1403
3200lb stocker 98 camaro.
Old 05-16-2018, 05:52 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
That's pretty high, but not crazy. Lowering the pressure will slow your reactions, but there isn't a ton there if you are keeping the pressure within reason.
I run 32-35 psi in my 3600# Super Street car. I typically bracket race it, and use starting line RPM to adjust reaction rather than tire pressure.
I can't tell if your question is:
1. I run 40 psi in my tires and I think it might be too high, but what will happen to my reaction times if I lower the pressure?
2. I need to slow my reaction times. Will lowering the pressure in my front tires accomplish this?
If #1, I'd probably drop 5 psi and you likely won't notice the difference. If #2, I'd still drop 5 psi, but you'll get more change in R/T through RPM adjustment or rear tire pressure.
S/ST 51
S/C 53
Old 05-16-2018, 06:14 PM   #5
Lee Valentine
Liked 319 Times in 68 Posts
More in lowering rear tire pressure so they wrinkle more.
Lee Valentine 1661 STK
Old 05-16-2018, 06:44 PM   #6
Kdw1403
I am trying to slow my reaction time down. When I am green it is is about a 015-020 But I go red alot by about .012-.015. Don’t win many races when you go red. Just trying to slow down reaction time without changing my spot on the tree. I might need to lower both front and rear tire pressure. I know I could lower my starting line rpm some as well. Just try to see what you guys think the best way to do it is.
Old 05-17-2018, 02:27 PM   #7
superstock45
Drop front to 17psi
superstock45 is offline   Reply With Quote
