Liked 68 Times in 22 Posts
Want to try using blinder. I foot brake my car. It does not have sun visors. How do I make and uses blinder? It has full cage. How and what do most guys use?
I think jegs makes one that clips on to the cage. You can always make one. BTW they are a lot tougher to use if running after sundown!
I don't use a blunder but have tried it a few times. It will keep you from redlighting if you get get it set up right. You can make them from pretty much anything. I made a couple out of cardboard and Velcro with the Velcro holding it in place at the top of the strip along the windshield. I think they would work best with a 2-step but as Keith said they can be difficult after dark when the top 2 bulbs will "bleed" around your blinder.
Liked 115 Times in 29 Posts
Couple of notched aluminum plates, screwed to a cabinet hinge, hose-clamped to an aluminum rod, screwed to the front headliner valance. There are probably better ways, but this was worked for me for a couple of years now, hasn't loosened up or anything.
Mike Merk |
Liked 8,129 Times in 1,535 Posts
Find a superstock racer and he can fill you in on Blocking. At the next points race observe the cars in tech and you will see there are many ways to make and mount a blinder. You don’t get good at blocking overnight, sometimes it’s a work in progress. I have only witnessed a few that can block at night. A former SS world champ has told me numerous times that when darkness arrives the best place for a blinder is in the passenger seat.
I have seen a couple guys that incorporated a small 12 volt light mounted behind the blinder they would turn on at night so you didn't see the bleeding of the lights around the blinder. Like M.J. said it takes some time to get yourself and car dialed in but once you do I've seen guys that were deadly using it. I'm pretty much impatient and didn't spend much time with it, may go back and try it again once I start screwing up again!
