Old 07-23-2018, 10:03 PM   #1
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Default M/T 3054 or 3054ST?
Hello, I am a bracket racer but have learned a lot from this forum. I bracket race a 65 Comet with a 351C, Jerico with 3.08 first and a 4.86 gear. Leaf spring/ladder bar car. Currently runs 10.50's at 127 mph. My rear tires are probably 12 years old and pretty much done. I do not race a lot. I can only fit a 9" tire and have been using the regular 3054. I see they have a 3054 ST which is a harder compound tire.
I am trying to determine if ST tire would be better? I am also wondering why a harder compound would be more stick friendly? My local track starting line is not that great.
Any advice appreciated. Not opposed to Hoosier or Goodyear.
b.guggenmos is offline   Reply With Quote
Old 07-23-2018, 10:34 PM   #2
joe collins
Liked 22 Times in 16 Posts
Default Re: M/T 3054 or 3054ST?
The ST is for a stick car
joe collins is offline   Reply With Quote
Old 07-24-2018, 10:00 PM   #3
Don Anderson
Liked 25 Times in 9 Posts
Talking Re: M/T 3054 or 3054ST?
X2 !!
Don Anderson is offline   Reply With Quote
Old 07-25-2018, 12:18 AM   #4
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
As mentioned, the ST is the tire you want and don't worry about running tubes. Also keep in mind that different brands have more or less section width with Goodyears seeming to be the narrowest for any given size. If you have a tight fit now this may make up your mind on brand.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 07-25-2018, 06:43 AM   #5
Liked 10,837 Times in 2,252 Posts
The Goodyear 1909 is a big tire compared to the rest of the 9'' tires.
Old 07-24-2018, 01:19 AM   #6
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
You want the ST's as mentioned D07 compound. I have had both M/T's and Hoosier's. Hoosiers don't leak at all. Mickey's sure do.
QUOTE=b.guggenmos;568280]Hello, I am a bracket racer but have learned a lot from this forum. I bracket race a 65 Comet with a 351C, Jerico with 3.08 first and a 4.86 gear. Leaf spring/ladder bar car. Currently runs 10.50's at 127 mph. My rear tires are probably 12 years old and pretty much done. I do not race a lot. I can only fit a 9" tire and have been using the regular 3054. I see they have a 3054 ST which is a harder compound tire.
Any advice appreciated. Not opposed to Hoosier or Goodyear.[/QUOTE]
55 Chevy is offline   Reply With Quote
Old 07-25-2018, 06:29 PM   #7
Ed Wright
Ed Wright's Avatar
[/QUOTE]
Running radials, tubeless? Every Hoosier I've had leaked right through the sidewalls. The MTs I ran last year (I just walked out there to make sure) still have over 10 psi. I run them at 13. I have not use a Hoosier in two years, maybe that got better.
Ed Wright 4156 SS/JA
Old 07-25-2018, 06:50 PM   #8
Hacksaw
Liked 312 Times in 175 Posts
Ed: I have been running Hoosier radials for at least the last 10 years, and no problem with sidewall leaks
Old 07-25-2018, 09:44 PM   #9
Ed Wright
Ed Wright's Avatar
Light weight versions. I blamed it on a lack of rubber. I have a spray bottle of soapy water in the trailer. Spray the sidewalks of them and foamed everywhere. Only set I will ever own. A-B-A tested them against my MTs, both felt like dead hooking, 4 hun slower than the MTs. Three of that in 60'. Made a local bracket racer a deal on them. Two sets of MTs now.
If they are fastest for you, that's great. Besides the leaking, my car didn't like them.
Old 07-26-2018, 07:56 AM   #10
Hacksaw
I ran the MT radials when they where one of the first to offer a wide tire suitable for SS. Trouble was that sometimes I would just spin instantly after the trans brake release. The Hoosier tires seem to be much more forgiving.
