Old 03-17-2019, 12:04 PM   #1
John Cannata
Liked 6 Times in 3 Posts
Default BBF 460 Super Stock Engine
Asking $7,500 or BO
Best ET. 9.45 at 139mph in 3035lbs 1985 Mustang GT
1974 460cid 220hp NHRA rated at 300hp
Set NHRA National Record at 1.05 under the index in 2013
D3VE-A2A Cylinder heads done by Jacques Blais
Edelebrock Victor intake port matched to heads
Wilson spacer to Thermoquad carb
Custom Comp Cams solid roller cam
Crower lifters, Jessel rockers, 7/16 double taper pushrods
Danny Bee Belt Drive
Manley valves, PAC springs
Block 460 + .040 partially filled
Block has roller cam bearings and bronze lifter bushings
Eagle rods with JE pistons
ATI damper, MSD crank trigger, MSD billet distributor
Custom aluminum Moroso oil pan for Fox body Mustang
Custom 3 step headers for Fox body Mustang
ATI flex plate, Tilton starter, Meziere water pump, sheet metal valve
covers
JW Ultra Bell to C-4 trans. cert good to 2022
This engine was run last year at the Division 1 Atco National Open and Maple Grove Points meet. Went -.806 at Atco and -.741 at Maple Grove
Dyno and Flow sheets available for the buyer
Also have
1 set of ported D3VE-A2A heads with matching intake and cam.
1 Block 1/2 filled, .060 over
1 set of Childs & Albert(427-07B) NHRA Accepted Rods
1 set of 429 Ford Cobra Jet rods
1 New Tilton starter
Best offer on all items, I'm a motivated seller
Contact: John 860-918-2524
John Cannata is offline   Reply With Quote
Search this Thread:
Advanced Search
