Liked 276 Times in 27 Posts
After returning from a month "down South" working Div 2 races including both the Baby Gators and the Gatornationals I must comment on an important issue I found missing on a lot of racecars.
As stated in the 2019 NHRA rulebook, master cutoff switches MUST be clearly marked for the OFF position. That means both the left-right lever style and the push-pull type. It would seem simple to turn the switch off if an incident happens on the track. But let's look at it a different way. After an incident on track the first person to arrive at the scene will turn the master cutoff switch to the off position. The second person arriving may not know that the switch has been turned off and turn it the other way which would turn the system back on. This can happen when the switch is NOT clearly marked. The other one is the push-pull type. Everyone knows that push OFF is the way these switches work....or do they. Marking with a PUSH OFF label will assure that in an incident the power gets turned OFF. All it takes is for one person to pull the switch and the system is reactivated. Marking your master cutoff switch is a simple yet very important way to let everyone know which way is OFF. |
Liked 8,240 Times in 1,540 Posts
Thanks for the heads up Travis....that’s some valuable info right there....
Liked 62 Times in 29 Posts
It would only make sense for a push-pull type of lever to turn the power off when pushed, as in backing the car into a wall. But, common sense has not been too common for many, many years........
Any car I work on has that switch properly marked, I never want anything to happen to one of my friends or customers, as well as myself and family members driving one of our cars! |
Liked 931 Times in 265 Posts
Rulebook states "push" must be the off action on a push-pull type mechanism. And most of the levers on switches I'm aware of go CCW to turn off if it's mounted that way. Also states it must be marked.
I'm a fan of having some type of secondary cable or other way of operating the master from the driver's seat, for both safety and convenience. |
Liked 11,030 Times in 2,266 Posts
I have one in the car next to me that kills everything, just in case!
#6 | |
Liked 237 Times in 126 Posts
Ditto.
