Liked 53 Times in 16 Posts
I was reading the Jr. Stock book by Doug Boyce and came across where a guy went down to Lunati's shop to pick up a Stocker cam for his 56 Chevy M/SA car and how the Lunati cam really woke up the 265 and how he was able to run under the record with it.
Having somewhat of a idea on how the old Stock duration and stock lift cams worked, I would like to hear more about how these camshafts worked including with the stock valve spring rules? This is just for winter discussion fun..Thanks ! Will Lamprecht 65 Impala 396/325 Have Jerico for it. |
#2 | |
Liked 231 Times in 107 Posts
The best cam that I ever had in my 307 Chevy was an old CamDynamics Jr. Stock cam. As best I can remember it was a 929-G.
Liked 239 Times in 114 Posts
Also part of the spec was "checking clearance" The duration was measured after the lift at the valve hit the opening checking clearance then finished when the lift was at the closing checking clearance . It was good to have" big" checking clearances sent in by the factory . Overlap was checked the same way . NHRA tech had a really trick Degree Wheel that simplified the checking process .
Our Div 4 head tech inspector, Red Anderson, was also a good machinist. He made, and sold a really trick degree wheel.
I had one of those Lunati Jr Stock cams in my ‘56 when I set one of my records. During tear down Red told me “this thing does hit the numbers, but the ramps are way fast. I’m going to pass it this time, but we both know it’s wrong. I don’t want to see it again. Ran just as fast with a Cam Dynamics, which Red liked better next time he tore me down. The Lunati looked like a roller cam. Almost square lobes. LOL
Ed Wright 4156 SS/JA |
The "square lobe" cam profiles are known as "dwell" lobes. With a dwell lobe, you can basically put a lifter on top of the lobe and it will not fall off!
Don Teweles at General Kinetics, along with Joe Lunati were pioneers on dwell lobe Stocker camshafts in the early days. Cam Dynamics also created many Stocker dwell cams that were crazy fast too. After Don shuttered General Kinetics, my preferred brand was Cam Dynamics when Glen Steyer's was still at Crane Cams. Let's not forget that in the early days, although they checked duration, lift and overlap, the OEM's had submitted some crazy camshaft specs too, especially regarding overlap. |
#7 | |
I still have mine too. And his Deck Checker, uses a dial indicator.
#9 | |
Liked 320 Times in 102 Posts
We ran a 929-D.... Wild and crazy guys who wanted to run a valve spring killer
Liked 56 Times in 33 Posts
Those were the type of cams and valve springs allowed in IHRA's Pure Stock classes !
