Old 01-06-2020, 11:50 AM   #1
bert powell
Liked 34 Times in 12 Posts
Default MPR 82 Camaro GT/IA 402
1982 Camaro coupe/claimed as 1986 (comes with title)
Chassis built by MPR Mike Pustelney
9" Ford with Mark Williams lightweight aluminum center section
Strange axles
5.83 Pro gear ---New
15"x14" weld wheels rear---15"x3" weld wheels front
Phoenix 14.5" x 32.0" bias tires rear---Goodyear tires front
Lamb brakes front and rear---rears are dual calipers
Koni adjustable shocks front, valved at True Choice, Koni double adjustable rear
Dual Exide batterys ---New
CRC combo fuel pump and filter---BG 4 port regulator---both just sent out for service
MSD ignition---7AL2 box ---HVC 2 coil
ACD air shifter and Hurst Quarter stick-- 2 air bottles just filled
Autometer play back Monster tach
New 5 gallon fuel cell
Rossler lightweight Turbo 400 with brake
Aluminum transmission shield
ATI 8" convertor---New
Dynotech aluminum drive shaft
New engine fresh off dyno
1970 402/300---NHRA rated at 308h.p.
GM 454 case with 8 sleeves---.060 overbore
GM steel crankshaft ---reworked
BME pistons
Eagle H beam rods----------ARP 2000 bolts
Comp cams roller cam and lifters
Jesel belt drive
Super Stock shoe box style oil pan with mini sump
ATI balancer with aluminum hub
MSD crank trigger
GM 820 cyclinder head castings
Manley valves
Comp Cams 948 springs
Jesel rocker arms
Trend pushrods
Dart inlet manifold
9207 Quadrajet
Davis 3 step headers---just ceramic coated
This car has gone 9.49 @ 139.6 mph @ 3275#s
Will run GT/IA at 3250#s---GT/IA index is 10.65
Many spare parts also available.
See Racing Junk Ad 183152801
Will sell complete for $38k or reasonable offer, or will sell engine only.
Call Vince 586-749-0200 business hours. No texts.
bert powell is offline   Reply With Quote
Old 01-06-2020, 12:33 PM   #2
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: MPR 82 Camaro GT/IA 402
Is that a 1971 402/300, NHRA 308 HP.The 1970 had more comp.and different heads and a higher HP factor...gsa612
Old 01-07-2020, 09:58 AM   #3
bert powell
Yes, '71 402 rated 308hp
Search this Thread:
Advanced Search
