Old 01-12-2020, 12:21 PM   #1
ZenzenRacing
Liked 53 Times in 17 Posts
Cool Trans Yoke Roller Tail
Does anyone have or know who makes a Trans yoke for a T350 for a roller tail, with a 6.5 in from center of joint (1350) to the yoke end? Only one I can find is a Moser that's a 6in center to end.
ZenzenRacing is offline   Reply With Quote
Old 01-12-2020, 01:05 PM   #2
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Trans Yoke Roller Tail
I didn't go through the full list, but Sonnax has a selection of performance yokes.
https://www.sonnax.com/slip_yokes
Good luck!
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 01-12-2020, 02:47 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Every billet 1350 yoke I've used in the last several years is 6" long , roller or bushing .
With the yoke properly engaged into the trans there should be no need for a longer one .
If the driveshaft is too short and you need the extra 1/2" to get the yoke into the bearing ,you're setting yourself up for other possible issues .
Besides stressing the splines ,the yoke can bind on the spline when the yoke is too far out on the shaft.
Old 01-13-2020, 12:42 AM   #4
killintime6968
Liked 91 Times in 29 Posts
Did you try Mark Williams
Bruce Cameron
68 Nova 396 E/S
68 Camaro SS/? ex Checkmate Modified
killintime6968 is offline   Reply With Quote
