Old 02-02-2020, 07:01 PM   #1
dlux
Liked 18 Times in 2 Posts
Default For Sale or Trade 289 Super Stocker Parts
Complete 289 SS engine
385lb-ft @ 5900rpm
479hp @7300rpm
Oct 2013
- 289 Mexico Block (used and freshened)
- Zero balance rotating assembly steel crank +.003 stroke .040 under main bearings (used and freshened
- Shot peened, polished rods .040 under rod bearings (used and freshened)
- JE pistons .070 over with new Dykes two ring set (used and freshened)
- New roller timing chain set
- New Milodon oil pan
- New Melling oil pump and pick up
- New zero balanced flexplate sfi certified
- ATI damper zero balanced
- CSI waterpump (used)
- New ARP flywheel bolts
- New ARP head bolts
- Comp Cam full roller solid cam lifters (used)
- Comp cam (used)
- Edelbrock Victor Jr intake (used)
- 1 set of Kip Martin prepared heads (iron used)
- I set of Kip Martin valve covers (used)
- 1 new set of Jesel shaft rockers, shafts, stands and hardware.
- New Meziere electric water pumps
289 Parts
- 1 set of Jimmy Bridges prepared Super Stock 289 heads complete (iron used)
- 9”Ford ring and pinion high performance competition 6.33/1 with 77 runs
- US Gear High Performance Competition Gear Set 6.66/1 with 53 passes
- C4 Stock Eliminator JPT race transmission with Bellhousing. Built for low friction with lightweight components. 2.75 first gear
- Mark William 35 spline gun drilled lightened axles. 21.5” long and 23.625” long, 5 x 4.5 BC new
dlux is offline   Reply With Quote
Old 02-03-2020, 06:30 PM   #2
Muscrate
Default Re: For Sale or Trade 289 Super Stocker Parts
I wrote you a PM for your c4
Muscrate is offline   Reply With Quote
Search this Thread:
Advanced Search
